260
##### MediaInfo ###### General Unique ID : 138544182337272347820214930152879673104 (0x683AA391778B4C50A51C3D90BD19CF10) Complete name : 千秋令.Destiny.and.Saving.S01E12.2025.2160p.WEB-DL.AAC.H265-ZeroTV.mkv Duration : 44 min 35 s Overall bit rate : 5 232 kb/s Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L5@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 44 min 35 s Bit rate : 5 040 kb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Bits/(Pixel*Frame) : 0.024 Stream size : 1.57 GiB (96%) Writing library : 200910.mgtv.com Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : A_AAC-2 Duration : 44 min 35 s Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Stream size : 60.5 MiB (4%) Title : 普通话 Language : Chinese Default : Yes Forced : No
举报
本版积分规则 发表回复 回帖后跳转到最后一页
|智能设备 | 粤ICP备2024353841号-1
GMT+8, 2025-5-1 21:23 , Processed in 4.205023 second(s), 24 queries .
