247
##### MediaInfo ###### General Unique ID : 62873781966792297194272595809245142921 (0x2F4D0CC8E970C1ECEE0536C2A2B91F89) Complete name : 爱的季风掠过.The.Monsoon.of.Love.Passes.by.S01E01.2025.1080p.WEB-DL.AAC.H264-ZeroTV.mkv Duration : 35 min 16 s Overall bit rate : 889 kb/s Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L5 Format settings : CABAC / 5 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 5 frames Codec ID : V_MPEG4/ISO/AVC Duration : 35 min 16 s Bit rate : 791 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.015 Stream size : 200 MiB (89%) Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : A_AAC-2 Duration : 35 min 16 s Bit rate : 96.0 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Stream size : 24.2 MiB (11%) Title : 普通话 Language : Chinese Default : Yes Forced : No
举报
本版积分规则 发表回复 回帖后跳转到最后一页
|智能设备 | 粤ICP备2024353841号-1
GMT+8, 2025-5-2 03:12 , Processed in 2.534576 second(s), 24 queries .
