查看: 9|回复: 0
无忧渡[杜比视界版本][第09
查看: 9|回复: 0
无忧渡[杜比视界版本][第09
查看: 9|回复: 0
246
COPjS7aQKkj
246
2025-4-16 04:11:29 | 显示全部楼层 |阅读模式
完整标题:无忧渡[杜比视界版本][第09-12集][国语音轨/简繁英字幕].2025.2160p.WEB-DL.DDP5.1.H265.DV-MiniTV 7.47GB
◎标  题 无忧渡
◎类  别 剧情 / 奇幻 / 古装
◎导  演 林玉芬 Yuk-Fan Lam
       梁胜权 Sing Kuen Leung
       黄肖英 Xiaoying Huang
◎编  剧 赵娜 Na Zhao
       缪文静 Wenjing Miu
◎演  员 任嘉伦 Jialun Ren
       宋祖儿 Zuer Song
       宣言 Yan Xuan
       范帅琦 Shuaiqi Fan
       赫雷 Lei He
       刘若谷 Ruogu Liu
       刘琪锜 Kiki Liu
       姚一奇 Yiqi Yao
       张垒 Lei Zhang
       曹骏 Jun Cao
       陈家乐 Carlos Chan
       哈妮克孜 Hani Kyzy
       黑子 Zi Hei
       孙天宇 Tianyu Sun
       徐百慧 Baihui Xu
       李彧 Yu Li
       李进荣 Jinrong Li
       宗峰岩 Fengyan Zong
       陈依莎 Yisha Chen
       王伊瑶 Yiyao Wang
       魏子昕 Zixin Wei
       张子鑫 Zixin Zhang
       吴崇轩 Chongxuan Wu
Unique ID                                : 179972061408069247811331668902426668854 (0x87655BB46E05D532B9FFF840835B6F36)
Complete name                            : 无忧渡.The.Demon.Hunter's.Romance.S01E09.2025.2160p.WEB-DL.DDP5.1.H265.DV-MiniTV.mkv
Duration                                 : 47 min 25 s
Overall bit rate                         : 5 577 kb/s
Bit rate                                 : 5 060 kb/s
Bits/(Pixel*Frame)                       : 0.033
Stream size                              : 1.68 GiB (91%)
Audio #1
Stream size                              : 86.8 MiB (5%)
Audio #2
Duration                                 : 42 min 29 s
Bit rate                                 : 43 b/s
Frame rate                               : 0.333 FPS
Count of elements                        : 849
Stream size                              : 13.6 KiB (0%)
Bit rate                                 : 43 b/s
Text #3
Duration                                 : 42 min 36 s
Bit rate                                 : 68 b/s
Frame rate                               : 0.335 FPS
Count of elements                        : 856
Stream size                              : 21.5 KiB (0%)
Text #4
Bit rate                                 : 71 b/s
Stream size                              : 22.3 KiB (0%)
Text #5
Bit rate                                 : 144 b/s
Stream size                              : 45.0 KiB (0%)
Text #6
Stream size                              : 19.1 KiB (0%)
Text #7
Stream size                              : 19.2 KiB (0%)
Text #8
Bit rate                                 : 63 b/s
Stream size                              : 19.7 KiB (0%)
Text #9
Bit rate                                 : 77 b/s
Stream size                              : 24.3 KiB (0%)
Text #10
Bit rate                                 : 82 b/s
Stream size                              : 25.8 KiB (0%)
Text #11
Bit rate                                 : 66 b/s
Stream size                              : 20.8 KiB (0%)
Text #12
Stream size                              : 19.4 KiB (0%)
GMT+8, 2025-5-1 21:35 , Processed in 2.716983 second(s), 23 queries .
