395
##### MediaInfo ###### General Unique ID : 140589506404786634082950013839292327405 (0x69C48DD497C7372E2FF5479D970165ED) Complete name : 成凰录.Phoenix's.Gambit.Love.or.Crown.S01E13.2025.2160p.EDR.WEB-DL.DDP2.0.H265-ZeroTV.mkv Duration : 18 min 9 s Overall bit rate : 16.5 Mb/s Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L5@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 18 min 9 s Bit rate : 16.2 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Bits/(Pixel*Frame) : 0.078 Stream size : 2.06 GiB (98%) Default : Yes Forced : No Audio #1 ID : 2 Format : E-AC-3 Format/Info : Enhanced AC-3 Commercial name : Dolby Digital Plus Codec ID : A_EAC3 Duration : 18 min 9 s Bit rate mode : Constant Bit rate : 96.0 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 12.5 MiB (1%) Title : 普通话 Language : Chinese Service kind : Complete Main Default : Yes Forced : No Audio #2 ID : 3 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : A_AAC-2 Duration : 18 min 9 s Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Stream size : 24.6 MiB (1%) Title : 普通话 Language : Chinese Default : Yes Forced : No
举报
本版积分规则 发表回复 回帖后跳转到最后一页
|智能设备 | 粤ICP备2024353841号-1
GMT+8, 2025-5-2 15:03 , Processed in 2.949873 second(s), 24 queries .
