Unique ID : 246078958637730806019107843171676070903 (0xB921156111A1542896D02D4D4D6023F7)
Complete name : 成凰录.Phoenix's.Gambit.Love.or.Crown.S01E11.2025.1080p.WEB-DL.DDP2.0.H264-MiniTV.mkv
Duration : 18 min 3 s
Overall bit rate : 2 484 kb/s
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings : CABAC / 3 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 3 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 2 195 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 24.899 FPS
Original frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.043
Stream size : 283 MiB (88%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : E-AC-3
Format/Info : Enhanced AC-3
Commercial name : Dolby Digital Plus
Codec ID : A_EAC3
Bit rate mode : Constant
Bit rate : 96.0 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 12.4 MiB (4%)
Title : Mandarin
Language : Chinese
Service kind : Complete Main
Default : Yes
Forced : No
Audio #2
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Bit rate : 192 kb/s
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Stream size : 24.4 MiB (8%)
Title : Mandarin
Language : Chinese
Default : No
Forced : No
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 15 min 29 s
Bit rate : 50 b/s
Frame rate : 0.379 FPS
Count of elements : 352
Stream size : 5.73 KiB (0%)
Title : Simplified
Language : Chinese
Default : Yes
Forced : No
Format : UTF-8
Bit rate : 50 b/s
Title : Traditional
Language : Chinese
Default : No
Forced : No
Text #3
Format : UTF-8
Duration : 15 min 36 s
Bit rate : 82 b/s
Frame rate : 0.407 FPS
Count of elements : 381
Stream size : 9.39 KiB (0%)
Title : English
Language : English
Default : No
Forced : No
Text #4
Format : UTF-8
Bit rate : 81 b/s
Frame rate : 0.405 FPS
Count of elements : 379
Stream size : 9.29 KiB (0%)
Title : Korean
Language : Korean
Default : No
Forced : No
Text #5
Format : UTF-8
Bit rate : 108 b/s
Stream size : 12.4 KiB (0%)
Title : Japanese
Language : Japanese
Default : No
Forced : No
Text #6
Format : UTF-8
Bit rate : 101 b/s
Stream size : 11.6 KiB (0%)
Title : Vietnamese
Language : Vietnamese
Default : No
Forced : No
Text #7
Format : UTF-8
Bit rate : 89 b/s
Stream size : 10.2 KiB (0%)
Title : Spanish
Language : Spanish
Default : No
Forced : No
Text #8
Format : UTF-8
Bit rate : 92 b/s
Stream size : 10.5 KiB (0%)
Title : Portuguese
Language : Portuguese
Default : No
Forced : No
Text #9
Format : UTF-8
Bit rate : 119 b/s
Stream size : 13.6 KiB (0%)
Title : Arabic
Language : Arabic
Default : No
Forced : No
Text #10
Format : UTF-8
Bit rate : 89 b/s
Title : Malay
Language : Malay
Default : No
Forced : No
Text #11
Format : UTF-8
Bit rate : 187 b/s
Stream size : 21.4 KiB (0%)
Title : Thai
Language : Thai
Default : No
Forced : No
Text #12
Format : UTF-8
Bit rate : 85 b/s
Stream size : 9.80 KiB (0%)
Title : Indonesian
Language : Indonesian
Default : No
Forced : No
