249
##### MediaInfo ###### General Unique ID : 311786412233416546400931362290589709571 (0xEA8FE0F63DB44CE18FB75583BD4B3503) Complete name : 格林.Grimm.S03E13.2013.1080p.Max.WEB-DL.DDP2.0.H264-ZeroTV.mkv Duration : 41 min 15 s Overall bit rate mode : Variable Overall bit rate : 5 266 kb/s Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 41 min 15 s Bit rate mode : Variable Bit rate : 5 135 kb/s Maximum bit rate : 11.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.099 Stream size : 1.48 GiB (98%) Writing library : x264 core 164 Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=24 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / stitchable=1 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=100 / keyint_min=51 / scenecut=0 / intra_refresh=0 / rc_lookahead=100 / rc=crf / mbtree=1 / crf=21.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=11000 / vbv_bufsize=40000 / crf_max=0.0 / nal_hrd=vbr / filler=0 / ip_ratio=1.40 / aq=1:1.00 Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 2 Format : E-AC-3 Format/Info : Enhanced AC-3 Commercial name : Dolby Digital Plus Codec ID : A_EAC3 Duration : 41 min 15 s Bit rate mode : Constant Bit rate : 128 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 37.8 MiB (2%) Language : English Service kind : Complete Main Default : Yes Forced : No Text #1 ID : 3 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 40 min 45 s Bit rate : 62 b/s Frame rate : 0.242 FPS Count of elements : 591 Stream size : 18.6 KiB (0%) Title : 简体 Language : Chinese Default : Yes Forced : No Text #2 ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 40 min 45 s Bit rate : 62 b/s Frame rate : 0.242 FPS Count of elements : 591 Stream size : 18.6 KiB (0%) Title : 繁體 Language : Chinese Default : No Forced : No Text #3 ID : 5 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 40 min 41 s Bit rate : 80 b/s Frame rate : 0.281 FPS Count of elements : 687 Stream size : 23.9 KiB (0%) Title : SDH Language : English Default : No Forced : No Text #4 ID : 6 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 40 min 28 s Bit rate : 69 b/s Frame rate : 0.255 FPS Count of elements : 618 Stream size : 20.6 KiB (0%) Language : Indonesian Default : No Forced : No Text #5 ID : 7 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 40 min 28 s Bit rate : 72 b/s Frame rate : 0.249 FPS Count of elements : 604 Stream size : 21.4 KiB (0%) Language : Malay Default : No Forced : No Text #6 ID : 8 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 40 min 28 s Bit rate : 168 b/s Frame rate : 0.246 FPS Count of elements : 597 Stream size : 49.9 KiB (0%) Language : Thai Default : No Forced : No Menu 00:00:00.000 : en:Chapter 1 00:40:40.840 : en:Credits 00:41:15.400 : en:Chapter 2
举报
本版积分规则 发表回复 回帖后跳转到最后一页
|智能设备 | 粤ICP备2024353841号-1
GMT+8, 2025-5-2 00:50 , Processed in 3.389585 second(s), 24 queries .
