完整标题:布道家庭.第四季[HDR/杜比视界双版本][第06集][简繁英字幕].2025.2160p.Max.WEB-DL.DDP5.1.Atmos.H265.HDR.DV-ZeroTV 5.04GB
◎标 题 布道家庭 第四季
◎片 名 The Righteous Gemstones Season 4
◎年 代 2025
◎产 地 美国
◎类 别 喜剧
◎语 言 英语
◎IMDb评分 8.8/10 (1274人评价)
◎IMDb链接 https://www.imdb.com/title/tt28503974/
◎豆瓣链接 https://movie.douban.com/subject/36493953/
◎编 剧 丹尼·麦克布莱德 Danny McBride
Unique ID : 202674071820620210429091722964520082038 (0x98799B3C2E0CF3591426D671CBCB1A76)
Complete name : 布道家庭.The.Righteous.Gemstones.S04E06.2025.2160p.Max.WEB-DL.DDP5.1.Atmos.H265.HDR.DV-ZeroTV.mkv
Duration : 36 min 32 s
Overall bit rate : 19.7 Mb/s
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@Main
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 19.1 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 0)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.096
Stream size : 4.87 GiB (97%)
Writing library : x265 3.5+1-f0c1022b6:[Linux][GCC 10.2.1][64 bit] 10bit
Encoding settings : cpuid=1176575 / frame-threads=4 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=0 / uhd-bd=0 / ref=3 / no-allow-non-conformance / repeat-headers / annexb / aud / no-eob / no-eos / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=96 / keyint=96 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=96 / lookahead-slices=8 / scenecut=40 / no-hist-scenecut / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=1 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / weightb / no-analyze-src-pics / deblock=0:0 / no-sao / no-sao-non-deblock / rd=3 / selective-sao=0 / early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=11.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=21900 / vbv-bufsize=40000 / vbv-init=0.9 / min-vbv-fullness=50.0 / max-vbv-fullness=80.0 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=0 / chromaloc-bottom=0 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1) / cll=353,122 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 353 cd/m2
Maximum Frame-Average Light Level : 122 cd/m2
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Commercial name : Dolby Digital Plus with Dolby Atmos
Codec ID : A_EAC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 167 MiB (3%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Complexity index : 16
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 34 min 57 s
Bit rate : 59 b/s
Frame rate : 0.240 FPS
Count of elements : 503
Stream size : 15.3 KiB (0%)
Title : 简体
Language : Chinese
Default : No
Forced : No
Format : UTF-8
Duration : 34 min 59 s
Bit rate : 57 b/s
Frame rate : 0.236 FPS
Count of elements : 496
Stream size : 14.7 KiB (0%)
Title : 繁體(香港)
Language : Chinese
Default : No
Forced : No
Text #3
Format : UTF-8
Duration : 34 min 56 s
Bit rate : 66 b/s
Frame rate : 0.260 FPS
Count of elements : 546
Stream size : 16.9 KiB (0%)
Title : 繁體
Language : Chinese
Default : No
Forced : No
Text #4
Format : UTF-8
Duration : 34 min 6 s
Bit rate : 74 b/s
Frame rate : 0.272 FPS
Count of elements : 556
Stream size : 18.7 KiB (0%)
Language : English
Default : No
Forced : No
Text #5
Format : UTF-8
Duration : 36 min 31 s
Bit rate : 80 b/s
Frame rate : 0.338 FPS
Count of elements : 741
Stream size : 21.4 KiB (0%)
Title : SDH
Language : English
Default : No
Forced : No
Text #6
Format : UTF-8
Duration : 36 min 21 s
Bit rate : 65 b/s
Frame rate : 0.271 FPS
Count of elements : 591
Stream size : 17.4 KiB (0%)
Title : Latin American
Language : Spanish
Default : No
Forced : No
Text #7
Format : UTF-8
Duration : 35 min 5 s
Bit rate : 72 b/s
Frame rate : 0.318 FPS
Count of elements : 670
Stream size : 18.6 KiB (0%)
Title : Latin American (SDH)
Language : Spanish
Default : No
Forced : No
Text #8
Format : UTF-8
Duration : 34 min 5 s
Bit rate : 73 b/s
Frame rate : 0.251 FPS
Count of elements : 514
Stream size : 18.3 KiB (0%)
Language : Indonesian
Default : No
Forced : No
Text #9
Format : UTF-8
Bit rate : 67 b/s
Frame rate : 0.254 FPS
Count of elements : 520
Language : Malay
Default : No
Forced : No
Text #10
Format : UTF-8
Bit rate : 64 b/s
Frame rate : 0.242 FPS
Count of elements : 528
Stream size : 17.2 KiB (0%)
Title : Brazilian
Language : Portuguese
Default : No
Forced : No
Text #11
Format : UTF-8
Duration : 34 min 50 s
Bit rate : 162 b/s
Count of elements : 543
Stream size : 41.5 KiB (0%)
Language : Thai
Default : No
Forced : No
Text #12
Format : UTF-8
Duration : 36 min 26 s
Bit rate : 54 b/s
Frame rate : 0.193 FPS
Count of elements : 422
Stream size : 14.5 KiB (0%)
Language : Turkish
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 1
00:36:23.480 : en:Credits
00:37:47.522 : en:Chapter 2
