227
##### MediaInfo ###### General Unique ID : 41402624605370517822278593318332759923 (0x1F25DAFECBA570CDA818F23EAE3D7F73) Complete name : 蛮好的人生.A.Better.Life.S01E01.2025.2160p.WEB-DL.AAC.H265-MiniTV.mkv Duration : 42 min 54 s Overall bit rate : 3 072 kb/s Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L5@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 42 min 54 s Bit rate : 2 878 kb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Bits/(Pixel*Frame) : 0.014 Stream size : 883 MiB (94%) Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : A_AAC-2 Duration : 42 min 54 s Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Delay relative to video : 14 ms Stream size : 58.9 MiB (6%) Title : 普通话 Language : Chinese Default : Yes Forced : No
举报
本版积分规则 发表回复 回帖后跳转到最后一页
|智能设备 | 粤ICP备2024353841号-1
GMT+8, 2025-5-2 01:36 , Processed in 3.757707 second(s), 24 queries .
