近期在寻找Go工程可以用的开源分库分表中间件,找了3个:ShardingSphere-Proxy,Kingshard,Gaea,下面给出测试过程和对比结果
https://github.com/apache/shardingsphere
有apache基金会支持,社区活跃, star 20.2k
Kingshard
https://github.com/flike/kingshard
个人项目, github已经不更新了,star 6.4k
Gaea
https://github.com/XiaoMi/Gaea
小米团队发布,最近更新是2024年9月,还算比较新,star 2.7k
分表设置
t_user 分10个表
sharding-proxy是 t_user_0...9
kingshard和Gaea是 t_user_0000...0009
测试代码
package mainimport ( "database/sql" "encoding/json" "fmt" "math/rand" "sharding/internal/models" "strings" _ "github.com/go-sql-driver/mysql" // 导入 MySQL 驱动 "log")const ( // 定义颜色的 ANSI 转义序列 Reset = "\033[0m" Red = "\033[31m" Green = "\033[32m" Yellow = "\033[33m" Blue = "\033[34m")func main() { log.Println(Red + "shardingsphere-proxy test" + Reset) dsn_proxy := "sharding:sharding@tcp(127.0.0.1:13308)/sharding_user?charset=utf8mb4&parseTime=True&loc=Local" sharding_query(dsn_proxy) log.Println(Yellow + "kingshard test" + Reset) dsn_kingshard := "kingshard:kingshard@tcp(127.0.0.1:9696)/sharding_user?charset=utf8mb4&parseTime=True&loc=Local" sharding_query(dsn_kingshard) log.Println(Blue + "gaea test" + Reset) dsn_gaea := "sharding_gaea:sharding_gaea@tcp(127.0.0.1:13306)/sharding_user?charset=utf8mb4&parseTime=True&loc=Local" sharding_query(dsn_gaea)}func sharding_query(dsn string) { //sharding proxy shardingProxyConn, err := sql.Open("mysql", dsn) if err != nil { log.Println(err) return } defer shardingProxyConn.Close() id := rand.Intn(10) userName := fmt.Sprintf("test%d", id) notFound := false // 完整sql,无传参 var uid uint64 valScope := strings.ReplaceAll(userName, "'", "\\'") err = shardingProxyConn.QueryRow(fmt.Sprintf("select id from t_user where login_name = '%s'", valScope)).Scan(&uid) if err != nil { if err == sql.ErrNoRows { log.Println("query 1 fail 1: ", err.Error()) notFound = true } else { log.Println("query 1 fail 2:", err) } } else { log.Println("query 1 success, uid=", uid) } // sql传参 err = shardingProxyConn.QueryRow("select id from t_user where login_name = ?", userName).Scan(&uid) if err != nil { if err == sql.ErrNoRows { log.Println("query 2 fail 1: ", err.Error()) notFound = true } else { log.Println("query 2 fail 2:", err) } } else { log.Println("query 2 success, uid=", uid) } // create if notFound { // sharding-proxy 有 id 自动生成配置,这里方便测试需要,指定id sqlIns := "INsert into t_user (id, login_name,passwd,email) values (?, ?, ?, ?)" result, err1 := shardingProxyConn.Exec(sqlIns, id, userName, "test1234", "test@test.com") if err1 != nil { log.Println("insert fail:", err1) } else { rowsAffected, _ := result.RowsAffected() log.Println("insert RowsAffected ", rowsAffected) } } //Select rows, err := shardingProxyConn.Query("select id,login_name,email,create_time,update_time from t_user where login_name like ? limit 10", "%test%") if err != nil { log.Println(err) return } defer rows.Close() var userList []models.UserModel for rows.Next() { var u models.UserModel e := rows.Scan(&u.ID, &u.LoginName, &u.Email, &u.CreatedTime, &u.UpdateTime) if e != nil { log.Println("row scan err:", e) continue } userList = append(userList, u) } j, _ := json.Marshal(userList) log.Println("select result:", string(j))}测试结论
shardingsphere-proxy 4.1
- 分表查询不支持占位符传参,插曲:php测试过支持传参使用
- 分表只支持全SQL
kingshard
- 分表查询支持全SQL
Gaea
结论对比
Go代码的工程应用想用分库分表中间件,推荐次序
第1首选优先Gaea,因为支持占位符传参,github最近更新是2024年9月
第2是shardingsphere-proxy 4.1,因为不支持占位符传参,go工程想要用,就全得转换成完整SQL,但是配置比较简单,容易部署,有apache基金会支持,社区活跃
第3是kingshard,因为不支持占位符传参,就全得转换成完整SQL,并且github已经不更新了
测试结果日志
2025/04/19 17:04:24 shardingsphere-proxy test2025/04/19 17:04:25 query 1 success, uid= 1119859588875681792[mysql] 2025/04/19 17:04:25 packets.go:64 [warn] unexpected seq nr: expected 4, got 52025/04/19 17:04:25 query 2 fail 2: commands out of sync. You can't run this command now[mysql] 2025/04/19 17:04:25 packets.go:64 [warn] unexpected seq nr: expected 8, got 172025/04/19 17:04:25 select result: null2025/04/19 17:04:25 kingshard test2025/04/19 17:04:25 query 1 success, uid= 42025/04/19 17:04:25 query 2 fail 2: Error 1105 (HY000): prepare error ERROR 1146 (42S02): Table 'sharding_user.t_user' doesn't exist2025/04/19 17:04:25 Error 1105 (HY000): prepare error ERROR 1146 (42S02): Table 'sharding_user.t_user' doesn't exist2025/04/19 17:04:25 gaea test2025/04/19 17:04:25 query 1 fail 1: sql: no rows in result set2025/04/19 17:04:25 query 2 fail 1: sql: no rows in result set2025/04/19 17:04:25 insert RowsAffected 12025/04/19 17:04:25 select result: [{"created_time":"2025-04-19T00:51:23+08:00","update_time":"2025-04-19T00:51:23+08:00","id":1,"Email":"test@test.com","LoginName":"test1","Passwd":"","LoginStatus":0,"LastLoginTime":null,"LoginCount":0}...] |
