千秋令[第21集][国语音轨/简繁英字幕].Destiny.and.Saving.S01.2025.2160p.WEB
HKm6XXtfqE
248
2025-4-21 07:55:38 | 显示全部楼层 |阅读模式
完整标题:千秋令[第21集][国语音轨/简繁英字幕].Destiny.and.Saving.S01.2025.2160p.WEB-DL.DDP2.0.H265-MiniTV 1.18GB
◎标  题 千秋令
◎译  名 Destiny and Saving
◎类  别 爱情 / 古装
◎导  演 麦贯之 Kun Chi Mak
       李伟基 Weiji Li
◎编  剧 步非烟 Feiyan Bu
       沈亿丽 Yili Shen
◎演  员 张予曦 Yuxi Zhang
       佟梦实 Mengshi Tong
       韩栋 Dong Han
       傅方俊 Fangjun Fu
       黄羿 Yi Huang
       陈紫函 Zihan Chen
       周紫馨 Zixin Zhou
       孟月晨 Peter Meng
       杜俊泽 Junze Du
       刘若谷 Ruogu Liu
       孙子聃 Zidan Sun
Unique ID                                : 307413746515253469226830925864172620608 (0xE745BBE5A78C8A9DB6941E15BF198B40)
Complete name                            : 千秋令.Destiny.and.Saving.S01E21.2025.2160p.WEB-DL.DDP2.0.H265-MiniTV.mkv
Duration                                 : 44 min 53 s
Overall bit rate                         : 3 762 kb/s
Duration                                 : 44 min 52 s
Bit rate                                 : 3 377 kb/s
Stream size                              : 1.06 GiB (90%)
Audio #1
Frame rate                               : 28.711 FPS (1536 SPF)
Stream size                              : 61.6 MiB (5%)
Audio #2
Stream size                              : 61.0 MiB (5%)
Duration                                 : 40 min 44 s
Bit rate                                 : 41 b/s
Frame rate                               : 0.274 FPS
Count of elements                        : 671
Stream size                              : 12.4 KiB (0%)
Bit rate                                 : 41 b/s
Text #3
Bit rate                                 : 63 b/s
Stream size                              : 18.9 KiB (0%)
Text #4
Duration                                 : 40 min 49 s
Bit rate                                 : 65 b/s
Frame rate                               : 0.285 FPS
Count of elements                        : 698
Stream size                              : 19.6 KiB (0%)
Text #5
Bit rate                                 : 72 b/s
Stream size                              : 21.6 KiB (0%)
Text #6
Bit rate                                 : 70 b/s
Stream size                              : 20.9 KiB (0%)
Text #7
Bit rate                                 : 85 b/s
Stream size                              : 25.6 KiB (0%)
Text #8
Stream size                              : 19.2 KiB (0%)
GMT+8, 2025-5-2 13:54 , Processed in 1.603368 second(s), 24 queries .
