237
##### MediaInfo ###### General Unique ID : 196686290887775581494745805420039945054 (0x93F866D796B530E1FBA989A60022BB5E) Complete name : 麻衣神婿.The.Plain.Clothes.God.Son.in.law.S01E13.2025.2160p.WEB-DL.DDP2.0.H265-ZeroTV.mkv Duration : 11 min 56 s Overall bit rate : 3 591 kb/s Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L5@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 11 min 56 s Bit rate : 3 320 kb/s Width : 3 840 pixels Height : 1 610 pixels Display aspect ratio : 2.40:1 Frame rate mode : Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Bits/(Pixel*Frame) : 0.021 Stream size : 283 MiB (92%) Writing library : Tencent-V265-1.6.9.3-p1k184g16lh64f4ra1. Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio #1 ID : 2 Format : E-AC-3 Format/Info : Enhanced AC-3 Commercial name : Dolby Digital Plus Codec ID : A_EAC3 Duration : 11 min 56 s Bit rate mode : Constant Bit rate : 144 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 12.3 MiB (4%) Title : 普通话 Language : Chinese Service kind : Complete Main Default : Yes Forced : No Audio #2 ID : 3 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : A_AAC-2 Duration : 11 min 56 s Bit rate : 125 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Stream size : 10.7 MiB (3%) Title : 普通话 Language : Chinese Default : Yes Forced : No
举报
本版积分规则 发表回复 回帖后跳转到最后一页
|智能设备 | 粤ICP备2024353841号-1
GMT+8, 2025-5-2 01:23 , Processed in 4.117065 second(s), 23 queries .
