259
##### MediaInfo ###### General Unique ID : 43420098961802361135240326030856090767 (0x20AA68292610C2116D7BC0DE72D0F48F) Complete name : 恋爱兄妹.My.Siblings.Romance.S01E16.2025.2160p.WEB-DL.H265.AAC-ColorTV.mkv Duration : 1 h 4 min Overall bit rate : 4 041 kb/s Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L5@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 1 h 4 min Bit rate : 3 849 kb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Bits/(Pixel*Frame) : 0.019 Stream size : 1.74 GiB (95%) Language : Chinese Default : Yes Forced : No Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : A_AAC-2 Duration : 1 h 4 min Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Stream size : 87.8 MiB (5%) Default : No Forced : No
举报
本版积分规则 发表回复 回帖后跳转到最后一页
|智能设备 | 粤ICP备2024353841号-1
GMT+8, 2025-5-1 23:14 , Processed in 2.898151 second(s), 23 queries .
