完整标题:探秘企鹅王国[国语配音/中文字幕].Penguin.Central.2019.1080p.WEB-DL.H264.AAC-PandaQT 0.50GB
◎标 题 探秘企鹅王国
◎译 名 企鹅中心
◎片 名 Penguin Central
◎年 代 2019
◎产 地 新西兰
◎类 别 纪录片
◎语 言 英语
◎豆瓣链接 https://movie.douban.com/subject/35382470/
◎片 长 50
◎简 介
Every winter, four penguin species breed in different locations in southern New Zealand: Fiordland crested penguins around the rugged Fiordland coast, yellow-eyed penguins on the sub-Antarctic Auckland Islands, little blue penguins near Oamaru and white-flippered penguins on Banks Peninsula. "Penguin Central" follows them as they mate, lay eggs and nurture their young to ensure their survival.
Complete name : 探秘企鹅王国.Penguin.Central.2019.1080p.WEB-DL.H264.AAC-PandaQT.mp4
Duration : 49 min 55 s
Overall bit rate mode : Variable
Overall bit rate : 1 416 kb/s
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5
Format settings : CABAC / 5 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 5 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 1 313 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.025
Stream size : 469 MiB (93%)
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : avcC
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate mode : Variable
Bit rate : 96.0 kb/s
Maximum bit rate : 99.7 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 34.3 MiB (7%)
Default : Yes
Alternate group : 1
