Netty 心跳机制实现(客户端与服务端)
JUzcbJUv2TXc
246
7 天前 | 显示全部楼层 |阅读模式
Netty 的心跳机制是保持长连接有效性的重要手段,可以检测连接是否存活并及时释放无效连接。下面介绍客户端和服务端的完整实现方案。
一、服务端实现
1. 基础心跳检测
public class HeartbeatServerInitializer extends ChannelInitializer<SocketChannel> {    @Override    protected void initChannel(SocketChannel ch) throws Exception {        ChannelPipeline pipeline = ch.pipeline();                // 添加编解码器        pipeline.addLast(new StringDecoder());        pipeline.addLast(new StringEncoder());                // 心跳检测        // 参数说明:readerIdleTime, writerIdleTime, allIdleTime, 时间单位        pipeline.addLast(new IdleStateHandler(5, 0, 0, TimeUnit.SECONDS));        pipeline.addLast(new HeartbeatServerHandler());    }}public class HeartbeatServerHandler extends ChannelInboundHandlerAdapter {    // 心跳丢失计数器    private Map<String, Integer> lossConnectMap = new HashMap<>();        @Override    public void userEventTriggered(ChannelHandlerContext ctx, Object evt) throws Exception {        if (evt instanceof IdleStateEvent) {            IdleStateEvent event = (IdleStateEvent) evt;            if (event.state() == IdleState.READER_IDLE) {                String socketAddress = ctx.channel().remoteAddress().toString();                int lossConnectCount = 0;                if (lossConnectMap.containsKey(socketAddress)) {                    lossConnectCount = lossConnectMap.get(socketAddress);                }                lossConnectCount++;                lossConnectMap.put(socketAddress, lossConnectCount);                logger.info("关闭不活跃: " + ctx.channel().remoteAddress() + " " + lossConnectCount);                if (lossConnectCount > 2) {                    logger.info("关闭不活跃连接: " + ctx.channel());                    ctx.channel().close();                }            }        } else {            super.userEventTriggered(ctx, evt);        }    }        @Override    public void channelRead(ChannelHandlerContext ctx, Object msg) {        // 收到任何消息都重置计数器        if ("HEARTBEAT".equals(msg)) {            if (lossConnectMap.containsKey(socketAddress)) {                lossConnectMap.put(socketAddress, 0);            }            System.out.println("收到心跳: " + ctx.channel());            ctx.writeAndFlush("HEARTBEAT_RESPONSE");        } else {            // 处理其他业务消息        }    }}2. 完整心跳交互方案
public class AdvancedHeartbeatServerHandler extends ChannelInboundHandlerAdapter {    private static final ByteBuf HEARTBEAT_SEQUENCE =         Unpooled.unreleasableBuffer(Unpooled.copiedBuffer("HEARTBEAT", CharsetUtil.UTF_8));        @Override    public void userEventTriggered(ChannelHandlerContext ctx, Object evt) throws Exception {        if (evt instanceof IdleStateEvent) {            IdleState state = ((IdleStateEvent) evt).state();            if (state == IdleState.READER_IDLE) {                // 读空闲(没有收到客户端消息)                System.out.println("读空闲,关闭连接: " + ctx.channel());                ctx.close();            } else if (state == IdleState.WRITER_IDLE) {                // 写空闲(可以主动发送心跳包)                System.out.println("写空闲,发送心跳包");                ctx.writeAndFlush(HEARTBEAT_SEQUENCE.duplicate())                   .addListener(ChannelFutureListener.CLOSE_ON_FAILURE);            }        } else {            super.userEventTriggered(ctx, evt);        }    }        @Override    public void channelRead(ChannelHandlerContext ctx, Object msg) {        String message = (String) msg;        if ("HEARTBEAT_REQUEST".equals(message)) {            // 响应客户端心跳            ctx.writeAndFlush("HEARTBEAT_RESPONSE");        } else {            // 处理业务消息        }    }}二、客户端实现
1. 基础心跳实现
public class HeartbeatClientInitializer extends ChannelInitializer<SocketChannel> {    @Override    protected void initChannel(SocketChannel ch) throws Exception {        ChannelPipeline pipeline = ch.pipeline();                pipeline.addLast(new StringDecoder());        pipeline.addLast(new StringEncoder());                // 客户端设置写空闲检测(定期发送心跳)        pipeline.addLast(new IdleStateHandler(0, 4, 0, TimeUnit.SECONDS));        pipeline.addLast(new HeartbeatClientHandler());    }}public class HeartbeatClientHandler extends ChannelInboundHandlerAdapter {    @Override    public void userEventTriggered(ChannelHandlerContext ctx, Object evt) throws Exception {        if (evt instanceof IdleStateEvent) {            IdleStateEvent event = (IdleStateEvent) evt;            if (event.state() == IdleState.WRITER_IDLE) {                // 写空闲时发送心跳                ctx.writeAndFlush("HEARTBEAT");                System.out.println("客户端发送心跳");            }        }    }        @Override    public void channelRead(ChannelHandlerContext ctx, Object msg) {        if ("HEARTBEAT_RESPONSE".equals(msg)) {            System.out.println("收到服务端心跳响应");        }    }}2. 完整心跳交互方案
public class AdvancedHeartbeatClientHandler extends ChannelInboundHandlerAdapter {    private static final ByteBuf HEARTBEAT_SEQUENCE =         Unpooled.unreleasableBuffer(Unpooled.copiedBuffer("HEARTBEAT_REQUEST", CharsetUtil.UTF_8));        @Override    public void channelActive(ChannelHandlerContext ctx) throws Exception {        // 连接建立后立即发送一次心跳        sendHeartbeat(ctx);        super.channelActive(ctx);    }        @Override    public void userEventTriggered(ChannelHandlerContext ctx, Object evt) throws Exception {        if (evt instanceof IdleStateEvent) {            IdleState state = ((IdleStateEvent) evt).state();            if (state == IdleState.WRITER_IDLE) {                // 写空闲时发送心跳                sendHeartbeat(ctx);            } else if (state == IdleState.READER_IDLE) {                // 读空闲(未收到服务端响应)                System.out.println("服务端无响应,关闭连接");                ctx.close();            }        } else {            super.userEventTriggered(ctx, evt);        }    }        private void sendHeartbeat(ChannelHandlerContext ctx) {        ctx.writeAndFlush(HEARTBEAT_SEQUENCE.duplicate())           .addListener(future -> {               if (!future.isSuccess()) {                   System.err.println("心跳发送失败: " + future.cause());               }           });    }        @Override    public void channelRead(ChannelHandlerContext ctx, Object msg) {        String message = (String) msg;        if ("HEARTBEAT".equals(message)) {            // 响应服务端心跳            ctx.writeAndFlush("HEARTBEAT_RESPONSE");        } else if ("HEARTBEAT_RESPONSE".equals(message)) {            // 收到服务端对客户端心跳的响应            System.out.println("心跳正常");        }    }}三、WebSocket 心跳实现
对于 WebSocket 连接,心跳机制需要特殊处理:
服务端实现
public class WebSocketHeartbeatServerHandler extends SimpleChannelInboundHandler<TextWebSocketFrame> {    @Override    protected void channelRead0(ChannelHandlerContext ctx, TextWebSocketFrame msg) throws Exception {        String text = msg.text();        if ("HEARTBEAT".equals(text)) {            ctx.writeAndFlush(new TextWebSocketFrame("HEARTBEAT_RESPONSE"));        } else {            // 处理其他WebSocket消息        }    }        @Override    public void userEventTriggered(ChannelHandlerContext ctx, Object evt) throws Exception {        if (evt instanceof IdleStateEvent) {            IdleStateEvent idleEvent = (IdleStateEvent) evt;            if (idleEvent.state() == IdleState.READER_IDLE) {                ctx.close();            } else if (idleEvent.state() == IdleState.WRITER_IDLE) {                ctx.writeAndFlush(new TextWebSocketFrame("HEARTBEAT"));            }        }    }}客户端实现
public class WebSocketHeartbeatClientHandler extends SimpleChannelInboundHandler<TextWebSocketFrame> {    @Override    protected void channelRead0(ChannelHandlerContext ctx, TextWebSocketFrame msg) throws Exception {        String text = msg.text();        if ("HEARTBEAT".equals(text)) {            ctx.writeAndFlush(new TextWebSocketFrame("HEARTBEAT_RESPONSE"));        }    }        @Override    public void userEventTriggered(ChannelHandlerContext ctx, Object evt) throws Exception {        if (evt instanceof IdleStateEvent) {            IdleStateEvent event = (IdleStateEvent) evt;            if (event.state() == IdleState.WRITER_IDLE) {                ctx.writeAndFlush(new TextWebSocketFrame("HEARTBEAT"));            }        }    }}四、最佳实践建议
  • 合理设置超时时间
    • 生产环境建议读空闲时间设置为60-120秒
    • 写空闲时间设置为30-60秒
  • 心跳协议设计
    • 使用固定格式的心跳消息(如"HEARTBEAT")
    • 可以考虑携带时间戳或序列号用于调试
  • 重连机制
    // 客户端重连示例public class ReconnectHandler extends ChannelInboundHandlerAdapter {    private final Bootstrap bootstrap;    private int retries = 0;        @Override    public void channelInactive(ChannelHandlerContext ctx) throws Exception {        if (retries < 3) {            long delay = 1L << retries;            retries++;            ctx.channel().eventLoop().schedule(() -> {                System.out.println("尝试重连..." + retries);                bootstrap.connect();            }, delay, TimeUnit.SECONDS);        }        ctx.fireChannelInactive();    }}
  • 监控与日志
    • 记录心跳异常情况
    • 监控连接存活率
  • 性能考虑
    • 使用共享的ByteBuf作为心跳消息
    • 避免在心跳处理器中执行耗时操作
通过以上实现,可以构建健壮的Netty心跳机制,有效维护长连接的可靠性。
Netty 心跳机制中写空闲检测的考量
在 Netty 心跳机制中,写空闲(WRITER_IDLE)检测和读空闲(READER_IDLE)检测各有不同的应用场景和考量因素。是否需要同时使用两者取决于具体业务需求。
一、写空闲检测的主要考虑场景
  • 客户端主动保活(最常见场景)
    • 当客户端需要维持与服务端的连接时(如移动设备通过NAT网关连接)
    • 防止中间设备(路由器、防火墙等)因长时间无数据流动而断开连接
    • 典型实现:客户端定期发送心跳包
  • 服务端主动检测(特殊场景)
    • 当服务端需要确认客户端是否存活但客户端无法主动发送心跳时
    • 双向心跳检测机制中
    • 需要服务端主动推送数据的场景(如实时监控系统)
  • 对称性心跳设计
    • 在金融、支付等对可靠性要求高的系统中
    • 双方向都保持活跃检测,提高连接可靠性
二、是否只需要读空闲检测?
可以仅使用读空闲检测的场景:
  • 纯服务端检测模式
    • 客户端会定期发送数据(包括业务数据和心跳)
    • 服务端只需要检测是否在指定时间内收到任何数据
  • 客户端可靠主动发送心跳
    • 客户端能保证按时发送心跳包
    • 网络环境稳定(如内网通信)
  • 节省资源考虑
    • 减少不必要的写操作
    • 简化心跳逻辑
需要同时使用写空闲检测的场景:
  • NAT环境下的长连接
    // 典型NAT环境下的客户端配置pipeline.addLast(new IdleStateHandler(0, 30, 0, TimeUnit.SECONDS)); // 只检测写空闲
  • 需要服务端主动保活的系统
    // 服务端需要保持连接活跃pipeline.addLast(new IdleStateHandler(60, 30, 0, TimeUnit.SECONDS)); // 读写都检测
  • 双向心跳验证
    // 高可靠性系统的心跳设计// 服务端:pipeline.addLast(new IdleStateHandler(60, 45, 0, TimeUnit.SECONDS));// 客户端:pipeline.addLast(new IdleStateHandler(75, 30, 0, TimeUnit.SECONDS));
三、实际应用建议
推荐方案1:客户端单边心跳(最常见)
// 客户端配置pipeline.addLast(new IdleStateHandler(0, 30, 0, TimeUnit.SECONDS)); // 只检测写空闲pipeline.addLast(new HeartbeatClientHandler());// 服务端配置pipeline.addLast(new IdleStateHandler(90, 0, 0, TimeUnit.SECONDS)); // 只检测读空闲适用场景:大多数移动应用、WebSocket通信等
优点
  • 客户端主动保活,避免NAT超时
  • 服务端只需检测客户端是否存活
  • 实现简单
推荐方案2:双向心跳检测
// 服务端配置pipeline.addLast(new IdleStateHandler(60, 45, 0, TimeUnit.SECONDS));// 客户端配置pipeline.addLast(new IdleStateHandler(75, 30, 0, TimeUnit.SECONDS));适用场景
  • 金融支付系统
  • 物联网关键设备通信
  • 对连接可靠性要求极高的场景
优点
  • 双方向连接状态确认
  • 更高的可靠性
  • 能更快发现单向网络中断情况
推荐方案3:自适应心跳
// 可根据网络条件动态调整public class AdaptiveIdleStateHandler extends IdleStateHandler {    private boolean isMobileNetwork;        public AdaptiveIdleStateHandler() {        super(60, 30, 0, TimeUnit.SECONDS);    }        @Override    protected long nextDelay(IdleState state) {        if (isMobileNetwork && state == IdleState.WRITER_IDLE) {            return 25; // 移动网络下更频繁发送        }        return super.nextDelay(state);    }}四、关键决策因素
  • 网络环境
    • 公网/NAT环境:需要写空闲检测
    • 内网环境:可能只需读空闲检测
  • 客户端类型
    • 移动设备:需要主动保活(写空闲)
    • 服务端:通常只需检测客户端是否存活(读空闲)
  • 业务需求
    • 普通消息推送:单边检测足够
    • 金融交易:建议双向检测
  • 资源消耗
    • 写空闲检测会增加少量网络流量
    • 读空闲检测不会产生额外流量
五、典型案例
案例1:IM即时通讯系统
// 客户端(移动设备)pipeline.addLast(new IdleStateHandler(0, 25, 0, TimeUnit.SECONDS)); // 只写空闲// 服务端pipeline.addLast(new IdleStateHandler(120, 0, 0, TimeUnit.SECONDS)); // 只读空闲理由:移动设备需要保持NAT映射,服务端只需确认客户端是否在线
案例2:物联网数据采集
// 设备端(客户端)pipeline.addLast(new IdleStateHandler(0, 60, 0, TimeUnit.SECONDS));// 服务端pipeline.addLast(new IdleStateHandler(180, 120, 0, TimeUnit.SECONDS));理由:设备可能处于不稳定网络环境,需要双方向检测
是否需要写空闲检测取决于具体场景:
  • 大多数情况下:客户端需要写空闲检测(主动保活),服务端只需读空闲检测
  • 高可靠性系统:建议使用双向检测
  • 内网稳定环境:可能只需读空闲检测
最佳实践是根据实际网络条件和业务需求,选择适当的组合方式。对于公网应用,特别是移动端,写空闲检测通常是必要的。
GMT+8, 2025-5-2 06:19 , Processed in 3.132786 second(s), 21 queries .
