X局密档[第15集][国语音轨/简繁英字幕].Secret.Files.of.XSA.S01.2025.1080p.WEB
nBy7ViMm
236
4 天前 | 显示全部楼层 |阅读模式
完整标题:X局密档[第15集][国语音轨/简繁英字幕].Secret.Files.of.XSA.S01.2025.1080p.WEB-DL.AAC.H264-MiniTV 0.38GB
◎标  题 X局密档
◎译  名 Secret Files of XSA
◎类  别 剧情 / 悬疑 / 犯罪
◎IMDb链接 https://www.imdb.com/title/tt36581338/
◎豆瓣链接 https://movie.douban.com/subject/37315376/
◎导  演 赵琦 Qi Zhao
◎编  剧 季雯 Wen Ji
       陈姝含 Shuhan Chen
       徐磊 Lei Xu
       赖继 Ji Lai
◎演  员 谷嘉诚 Jason Gu
       尚语贤 Yuxian Shang
       赵仁杰 Renjie Zhao
       林永健 Yongjian Lin
       许文广 Wenguang Xu
       董春辉 Chunhui Dong
       颜世魁 Shikui Yan
       栾元晖 Yuanhui Luan
       汤加文 Carmen Tong
    蔚蓝一号是一项举世瞩目的科研项目,为此境外间谍机构SAD实施破坏,被沙澎国操控的修罗则希望窃取它的核心技术。国安干警霍敏和队员们瓦解了SAD发起的阴谋、识破了修罗的渗透策略,最终将内鬼和间谍绳之以法。
Unique ID                                : 257407216715223959646351975850558171135 (0xC1A6D39FD074E632C9E750786CC127FF)
Complete name                            : X局密档.Secret.Files.of.XSA.S01E15.2025.1080p.WEB-DL.AAC.H264-MiniTV.mkv
Duration                                 : 46 min 30 s
Overall bit rate                         : 1 162 kb/s
Format settings                          : CABAC / 4 Ref Frames
Format settings, Reference frames        : 4 frames
Bit rate                                 : 1 065 kb/s
Height                                   : 804 pixels
Display aspect ratio                     : 2.40:1
Bits/(Pixel*Frame)                       : 0.028
Stream size                              : 354 MiB (92%)
Writing library                          : o264 V1.3.1@16974136userdata:ptw-1.16.2 cr-i12.0a40.0 rcm-adapt vs-93.0
Bit rate                                 : 93.4 kb/s
Frame rate                               : 46.875 FPS (1024 SPF)
Stream size                              : 31.1 MiB (8%)
Duration                                 : 41 min 8 s
Bit rate                                 : 31 b/s
Frame rate                               : 0.198 FPS
Count of elements                        : 489
Stream size                              : 9.60 KiB (0%)
Bit rate                                 : 31 b/s
Text #3
Duration                                 : 44 min 25 s
Bit rate                                 : 60 b/s
Frame rate                               : 0.199 FPS
Count of elements                        : 530
Stream size                              : 19.8 KiB (0%)
Title                                    : Arabic
Language                                 : Arabic
Text #4
Bit rate                                 : 38 b/s
Stream size                              : 12.7 KiB (0%)
Title                                    : English
Text #5
Bit rate                                 : 45 b/s
Stream size                              : 14.9 KiB (0%)
Title                                    : Spanish
Text #6
Duration                                 : 44 min 24 s
Bit rate                                 : 48 b/s
Frame rate                               : 0.165 FPS
Count of elements                        : 439
Stream size                              : 15.7 KiB (0%)
Title                                    : Indonesian
Text #7
Bit rate                                 : 44 b/s
Frame rate                               : 0.200 FPS
Count of elements                        : 533
Stream size                              : 14.4 KiB (0%)
Title                                    : Korean
Language                                 : Korean
Text #8
Bit rate                                 : 44 b/s
Stream size                              : 14.3 KiB (0%)
Title                                    : Malay
Text #9
Bit rate                                 : 44 b/s
Stream size                              : 14.6 KiB (0%)
Title                                    : Portuguese
Text #10
Bit rate                                 : 100 b/s
Stream size                              : 32.8 KiB (0%)
Title                                    : Thai
Language                                 : Thai
Text #11
Bit rate                                 : 58 b/s
Stream size                              : 19.2 KiB (0%)
Title                                    : Vietnamese
Language                                 : Vietnamese
GMT+8, 2025-5-1 11:54 , Processed in 1.432879 second(s), 24 queries .
